broncfan56
I'm in need of some advice. Last week the Galant started stuttering/bucking under boost levels above 10 lbs, I would let off the gas press the pedal again and all would be well. Yesterday the engine died due to loss of all fuel pressure. I hooked up the laptop today to test the fuel pump while the car was off. After a couple tries during which it didn't turn on at all, the pump then pushed fuel for about ten seconds with no problem followed by clicking from the fuel pump, and then died again.
I have swapped the MPI with 2 others with no effect, swapped the relay in the trunk (from rewire kit I believe) with no effect, and all fuses seem to be in working order, however these were done prior to testing the fuel pump.
Any thoughts on sensors or connections I should check? Bad fuel pump?
Fuel filter is clean, 6an lines, bosch 044 fuel pump running E85. Thanks for any help.
