Josh554
New member
I just bought #554/1000. I know that it will need a turbo to run because the one in it is completely shot but I figured I would try to start it first. It has been sitting for a couple months so I got some new fuel in it, put a battery in, connected everything and tried to start it but it wouldn't start up. It would start on starter fluid but it would only run off of the starter fluid. So the owner had told me some of the connectors were bad so I was checking everything with a multi-meter and I only got 8.5 volts dc at the fuel pump, I was wondering what you should normally get. Because I know that the injectors need enough pressure to work correctly. It is getting spark but nothing from the injectors.
Can anyone help me out?
