4wheelsqueal
Am looking to hook you my cyclone intake manifold. My buddy used it on his talon and had the butterfly's activated by the fuel pressure solenoid on his talon. Now I have gotten to out of his talon and want to put it on 555/2k, I can't find the fuel pressure selenoid on the galant. I found it should be by the stock air can but the two solenoids that are there aren't hooked up to anything and don't have the wire connector like the talon fuel solenoid had. Now looking under the hood of 713/1k there is a clip that's taped to the solenoid with the red and white wiring that lloks like the dsm fuel solenoid clip but can't find that clip on 555/2k. Is the solenoid with the red and white wiring the fuel solenoid or is it the one with the red and orange wiring? Want to use it this way because it worked perfectly on the talon this way. Thanks in advance. Can provide pics if needed.
