FS: TurboLab Bastard 20G, 2G Exhaust Manifold, Stainless o2 Housing
prestonztt
Oklahoma City, OK
Up for sale is a Turbo Lab Bastard 20g. Bought the turbo a few months ago and have only put about 500mi on it. But the car is down for the winter, so I figured I would start a bigger build. Turbo has no abnormal shaft play or anything. Mechanically perfect! Was never boosted over 20psi!
Condition: Excellent
Price: $350 Shipped
Specs:
Turbo Lab Bastard 16g
20g Compressor Wheel
TD05H Turbine Wheel
Evo 3 7cm Exhaust Housing
Ported Wastegate Flapper Hole
Also have a non-cracked 2G Exhaust Manifold that is ceramic coated - $75 Shipped
No-Name Stainless o2 Housing Ceramic Coasted - $50 Shipped
Does this have the Turbolab thrust components (18mm thrust spacer and "upgraded" thrust bearing)?
AllanL
NV
just for clarification, are there any issues with the 'upgraded' thrust parts from TurboLab?
or is the issue a general one affecting all 'upgraded' thrust parts, and not only the one from Turbolab?
Quoting AllanL:
There are no issues that I'm aware of. However, you may need to modify where the turbo is fed oil from depending on what thrust parts you have, and oil pressures being seen at the source. This goes for all the modified thrust components, not just the Turbolab ones. Ryan posted some really good info here: click . That thread should pretty much answer all questions.
