belize1334
There are lots of things on this shelf that I have no need for... all prices are shipped and include paypal fees so it's really simple. More pics available by request. Reasonable offers and package deals encouraged.
AutoMeter Pro-Comp Ultra-Lite -30/30 boost gauge: $40
*Just the gauge - no kit. Needle is nicely center 'cause I took the gauge apart and adjusted it. /ubbthreads/images/graemlins/wink.gif
6_bolt Fidanza Flywheel: $75 - SOLD
* used with puck disk - will need a new friction plate if used with organic or kevlar disc.
1G damper pulley: $40
* used but good condition
PWR/ECO switch & NOR/SP switch: $20 ea
Polished aluminum elbows: $15 ea
* small one is about 1.75" id
* large one is about 2.25" id
Drive shaft carrier bushings: $20
* used but rubber is not yet brittle
Front subframe bushings: $40
* used but rubber is not yet brittle - can include second set of smaller bushing for transverse front cross-member but missing upper oring...
Eibach coil springs with sleeves and hats: $60 - SOLD
* 8" x 2.5" x 300lb/in - pair
MAF adapter: $20
3" x 2g/3g plastic adapter - 'nuff said.
2awg welding cable: $25
11 ft, unterminated - great for battery relocation - I'll throw in the 2ft section of 4awg grounding cable if you're into it.
ISC: $25
tested good
'90 / JDM igniter: $25
91-94 tb w/ idle switch: $25
2g tb: $25
90 CAS: $25
plastic BOV cover shroud: $25
2.75 x 2.75 offset coupler from HPS: $25
3.0 x 2.25 offset coupler from AP: $25
3.0 x 2.75 straight reducer: $20
3.0 x 2.0 straight reducer: $20
3.0 x 2.75 elbow reducer: $20
Walbro 255 hp: $40 - SOLD
*GSS342 - used but works fine.
MAF adapter: $20
ISC: $25
tested good
2g tb: $25
90 CAS: $25
