DailyDSM
All prices include shipping to the lower 48.
Factory Double DIN Trim surround for Galant VR4 in decent condition condition with metal mounting brackets and hardware. I have multiple sets of these and can split up depending on what buyer needs. Willing to negotiate price depending on condition of trim ring.- $30 shipped
2G Throttle Body Elbow- Has SD IAT hole that has been sealed with aluminum cap/JB Weld- $15 Shipped
Galant VR4 RS Throttle Body Elbow- Believe this is the same diameter as the 2G Elbow (~5 cm/2 in) but slightly shorter.- $15 Shipped
E39A Ashtray. Had electronics installed in this so a small hole as cut into the back to accommodate wires. - $13 Shipped
Upper Timing Belt Cover (BLACK)- Has some scratches and the two upper mounting holes are cracked but works perfectly fine. - $13 Shipped
OEM Pickup tube with low mileage in excellent condition. Support bracket removed for use with Kiggly Girdle but worked perfectly fine. - $18 Shipped
Green Top CAS- $20 Shipped
Galant VR-4 Power Steering Reservoir. Used for AWS setups.-$13 shipped OBO
1992 DSM/GVR4 Water Pipe. Good shape but needs to be cleaned up-$22 shipped
ECU Fuel Pump Turn on Control Relay- Can’t remember which car this came out of but it might be a universal part (Part# E8T06971). Support bar can be included for an extra $5 for shipping- $12 shipped OBO
92 Water cooled oil filter housing with AN fitting for turbo oil feed line- $23 shipped
JDM GVR4 RS oil filter housing. This is an air-cooled housing similar to the 90 style oil filter housing but I don’t believe it has the provision for the OEM oil pressure sender. I believe a t-fitting can be used to run both USDM sensors. Needs a thorough cleaning but should work fine. -$23 shipped
Stock 2G DSM turbo intake pipe. Doesn’t have any of the breather nipples- $15 shipped
Lower Shores Manual Boost Controller- $20 shipped
Galant ECO/PWR Switch- $10 shipped
Power mirror control switch- $10 shipped
Valve cover to intake manifold/tb support bracket- $10 shipped OBO
1G OEM Fuel Rail (x2)- $15 shipped each OBO
<font color="black"> SOLD ITEMS <!--color--></font>
Stock Galant VR4 Spark Plug Cover: Slightly warped but fine when bolted down- $12 shipped OBO <font color="red"> SOLD <!--color--></font>
JDM Galant VR4 RS Engine Harness. Came off of JDM engine pullout and all connectors seem to be in good shape. - $100 Shipped ---- <font color="red"> SOLD <!--color--></font>
4G64 OEM Intake Cam Gear (50 Miles): Part# MD189399 - $15 Shipped -----<font color="red">SOLD <!--color--></font>
4G64 OEM Exhaust Cam Gear (50 Miles): Part# MD300439 - $15 Shipped ------ <font color="red">SOLD <!--color--></font>
4G64 OEM Timing Belt (50 Miles): Perfect Condition Part# MD331076 - $20 Shipped ----- <font color="red"> SOLD <!--color--></font>
1989 Galant Under-dash (Correct Color, Does not have vent tube) ---> <font color="red"> SOLD <!--color--></font>
Kiggly 6-Bolt Main Girdle- Price: $90 Shipped ---- <font color="red"> SOLD <!--color--></font>
HKS Type 1 Turbo Timer (Black US Spec) w/ 1G Harness- $50 Shipped ---- <font color="red"> SOLD <!--color--></font>
Galant VR4 Sending Unit w/ Russell -6AN Bulkhead fittings $75 shipped OBO---- <font color="red"> SOLD <!--color--></font>
12- Piece Non-Electric/Manual Seatbelt Conversion (KIT 2)- Usable Condition.
Price- $125 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
1990 Turbo Water Pipe- $20 Shipped --- <font color="red"> SOLD <!--color--></font>
2G MAF (609)- $35 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
1G Harness to 2G MAF Adapter- $12 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
Aluminum MAF to Filter Adapter 4.5"- $15 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
1G N/T DSM Throttle Body with sensors shown. Came off running car.- $35 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
Stock Galant VR4 Exhaust Manifold Heat Shield. Hole Drilled for EGT Sensor- $15 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
Haynes Service Manual for 1G DSMs - $10 shipped --- <font color="red"> SOLD <!--color--></font>
EVO 3 III Exhaust Manifold: Tapped for EGT Sensor- $95 Shipped OBO --- <font color="red"> SOLD <!--color--></font>
16- Piece Complete Non-Electric/Manual Seatbelt Conversion (KIT 1)- Excellent condition. Price- $280 shipped OBO ---- <font color="red"> SOLD <!--color--></font>
1989 Galant Glove box (Correct Color) - $40 Shipped --- <font color="red"> SOLD <!--color--></font>
Hyundai "Smooth" Valve Cover- $35 Shippedd --- <font color="red"> SOLD <!--color--></font>
OEM Galant Double DIN Trim Ring. Good Condition and no broken tabs.- $30 shipped OBO <font color="red"> SOLD to EgonOlsen <!--color--></font>
OEM Double DIN Stereo Brackets.- $20 shipped OBO <font color="red"> SOLD to EgonOlsen <!--color--></font>
3-Timing Tins- $25 Shipped for all 3 OBO <font color="red"> SOLD to 92VR4NYC <!--color--></font>
1G DSM Power Steering Reservoir.- $15 shipped OBO <font color="red"> SOLD to 92VR4NYC <!--color--></font>
Power Steering mounting bracket- $18 shipped OBO <font color="red"> SOLD to 92VR4NYC <!--color--></font>
Stock VR4 RS intake piping- $40 shipped OBO <font color="red"> SOLD to Drew84 <!--color--></font>
ARP Head bolt kit (Used).- $45 shipped <font color="red"> SOLD to 92VR4NYC <!--color--></font>
Set of 16 Brand New OEM Valve Stem Seals for 4G63- $15 Shipped <font color="red"> SOLD to strokin4dr <!--color--></font>
Timing side lower engine mount with timing pullies. Unknown mileage.- $25 shipped OBO --- <font color="red"> SOLD <!--color--></font>
Timing side forward engine mount. Has been notched to allow head removal when using ARP head studs.- $28 shipped OBO --- <font color="red"> SOLD <!--color--></font>
OEM Mitsubishi (NOT TOPLINE) Front Case w/ 50 miles in perfect condition. Price: $180 shipped OBO ---- <font color="red"> SOLD <!--color--></font>
2G Dejon Intake w/ Recirc. Tube Powdercoated Red. Oval shape to mate with stock 2G MAS and coupling for use with either T25 or 16G housing. Recirc. Tube is oriented for use with BOV in stock 2G location- $60 Shipped OBO <font color="red"> SOLD <!--color--></font>
JM Fabrications/LZM FIAV Bypass Plate- $9 Shipped <font color="red"> SOLD <!--color--></font>
Stock 1G O2 Sensor- $15 shipped <font color="red"> SOLD <!--color--></font>
NGK Spark Plug Wires for Cyclone intake manifold. These are well used and came off a JDM VR4 RS engine with the cyclone intake manifold so they are the proper length. They worked fine for me when I was using them to try out the cyclone manifold for a few months- $10 shipped <font color="red"> SOLD <!--color--></font>
Stainless Steel Fuel Feed Line Kit (Stock Filter to Rail). Male to Male AN fuel filter fitting not pictured but is included.- $40 shipped <font color="red"> SOLD <!--color--></font>
Evo3/GVR4 RS Yellow top 510cc fuel injectors. - $60 shipped OBO --- <font color="red"> SOLD <!--color--></font>
Galant Grille - $40 shipped OBO --- <font color="red"> SOLD <!--color--></font>
Upper Timing Belt Cover (GREY)- Has some scratches and usual wear but overall good condition. - $13 Shipped
1G Turbo Throttle Body w/ FIAV Blockoff Plate. This came with an intake I bought years ago and seems to be in good working condition. - <font color="red"> SOLD <!--color--></font>
