FS: Random goodies
VR4Scott
Orlando, FL, USA
I cleaned up the shop a bit and gathered some things to post for sale:
Brand new OEM 2g non abs proportion valve - $40
Green top CAS - $30
Black top CAS (Made in 2009) - $80
Stock 2g Infinity amp - $20
95 Eprom TCU - $50
2g 609 MAF - $30
Crushed 1g BOV - $30
Stock 7 bolt FWD flywheel - $20
2GB blacked out headlights - $50
GVR4 thermostat housing - $20
Energy Suspension 2g front upper control arm bushings - $15
Good 2g window regulators with motor - $20 each
Rare early 95 2g eclipse (evo 3) rear big brake setup; rotors, calipers, hardware, brake hoses - $100
2g AWD rear hub assemblies, need new studs - $40 each
1g to 2g MAF harness adapter - $20
(3) 7 bolt/evo 162mm super long rod Manley Turbo Tuff rods mounted with 9:1 87mm Wiseco 1400HD pistons - $400
Get another rod, piston, and ring set and you'll have 2.1 destroker internals for less than a grand.
Prices are plus shipping or make a shipped offer.
460GVR4
tacoma, wa
thermostat housing as in entire water outlet with sensors that bolts to cylinder head?
VR4Scott
Orlando, FL, USA
Yes entire thermostat housing with sensors.
I took the cop plates off because I found out they don't fit correctly. The bolt holes are slightly off and they don't sit flush in the valve cover because they are slightly too big. I wouldn't feel right selling them even for 10 bucks, unless you're ok with having to mod it to fit.
