FS: Parting out a 91 GSX.
grocery_getter
I have at the shop a red abs 5 speed 91 GSX that is going to be fully parted out down to the shell. Aside from the usual stuff, that means steering rack, steering column, pedal assembly, shifter base, the whole front subframe, front suspension, brake setup, knuckle/ hub etc, driveshaft, the whole rear subframe and rear suspension as well. Let me know if there is any special request. The shell will be parted out to a non rolling status and be dragged out of here on a flat bed.
The timing belt broke and it bents the valves. The bottom end is great condition, peeking in from the spark plug hole, all 4 pistons looks dry from the top! Cranking the motor with the starter shows all 4 pistons moving up and down smoothly in their bores.
I'll put some pictures up to give ideas of what's there. Pictures will save me time from typing it all out.
Let me know what you guys need. As you can see, I am selling it all cheap !!
Perfect condition instrument panel 148,587 miles $25
Pioneer CD deck with remote control $25 SOLD
Red front bumper skin - great condition $25
Red rear bumper skin - great condition $25
Red driver side and passenger side front fender set $50 for both SOLD
Great condition - all front lights (side corner, front piece under the headlight - both sides so 4 pieces total in this set) $50 for all SOLD
Great condition - no crack at all - talon front middle trim piece between the lights and under the hood $25 SOLD
Great condition red flip up headlights complete with buckets and metal cover $50 for both SOLD
Carbon fiber rear tail light set $50 SOLD
Middle rear talon panel $25 SOLD
Front spindle left and right $50 for both SOLD
Front big brake dual piston calipers left and right $50 for both comes with the left and right front brake rotors for free
Rear brake calipers left and right $50 for both comes with the left and right rear brake rotors for free
Main fan $25
AC fan $25
91 ecu non eprom $50 SOLD
Shifter base plate $25
Shifter cable with dual adjustable ends $25
Speedo cable $25
Left and right door. Complete assembly on both with glass intact - $50 for both doors set
Tubular manifold - 16G - tubular O2 housing $500 for the set. - turbo in really good condition. SOLD
Fake Greddy BOV $25
Battery - great condition $25
450cc injectors and resistor pack $75 SOLD
ABS pump $25
4 swirl talon wheels and tires and spare tire $150 for all 5 tires/rim set
Great condition red hood $50
Front subframe with 1G steering rack $25
Rear subframe and mustache member $25
3 bolt rear diff with axles $100 SOLD
1G steering rack with mounting bushings and brackets $50
Trailing arm no more spindle but complete with upper and lower lateral arm on both $25 for both side
spooln4fun
Belpre, OH
I may be interested in the Passenger door cover. Mine has the black piece broke on it and also if you have the little screw covers that go on both sides. Roughly 1/2" by 1/2" near the interior door handle. Lmk
grocery_getter
What a long Saturday it was. Stripped the whole car in 6 hours. Got a lot of pictures, I'll upload them here soon.
There are a ton more of parts that were put into a pile for recycling. front and rear subframes, steering rack, front and rear brakes, cross members, etc. So let me know what you need and I'll try to get it out and take a picture of it.
Ok, here they are...
grocery_getter
Quoting spooln4fun:
I have both driver and passenger doors complete in good condition. PM me picture or post picture of what you want so there is no miscommunication.
grocery_getter
I'm keeping the bottom end and head with bent valve combo for now (from the valve cover to the oil pan). The long block is about the only thing that I really want to keep from this part out. Everything else is for sale. What are you looking for?
i would will take the bumper skins for the front and rear, and also the middle trim pieces that run along side of the doors (in the center) how much for those all together shipped to 77079?
mitsuturbo
Near Seattle, Washington
Quoting grocery_getter:
Just a good core, really. Always looking for a good core for cheap, especially local.
