RyanInWheeling
Thule roof rack. NO FEET 100.00
Oil Sending Unit. NEW IN BOX 15.00
Used Egr Valve 15.00
OEM License plate bracket 30.00
New antenna has white gearing on bottom NO MOTOR. 30.00
Wiper motors 20.00 each 2 to choose from
Used ICS 15.00
Old school HKS Turbo timer with GVR4 Harness 50.00
OEM parking brake cables New in bag 50.00
Front Tower Braces 50.00 each 2 available both polished, 1 with red ends 1 with black
Spal Fans 2 of them both wired for inside of radiator 40.00 each
Reman front axles shafts seem thicker than stock. Less than 1k miles with half shaft 100.00 or 40.00 each without half shaft
Rear H/R springs 50.00
New in box Mitsubishi o2 sensor 90.00
Black timing belt cover 25.00
Unorthodox under drive pulley 30.00
4 door handle backs INTERIOR 10.00 each
Rear door ash trays 15.00 each
A/C brackets and compressor " no bolts on tension pulley 100.00 for all
Purge valve 20.00 2 available
SAFC 1 silver 75.00
Aluminum dual gauge pod. Fits under radio 30.00
Used ICS 15.00
SAFC 1 silver 75.00
