FS: Massive part out. Lots of aftermarket stuff: Engine, trans, turbo, etc...
cody
Neenah, WI
All Parts have less than 3,000 miles, NO TRACK TIME. Or Dyno #’s, Sorry.
Prices do not include shipping and paypal fees.
Please call or text 920-540-2529. Parts are located in Appleton, WI. Thanks.
Parts for sale
Apexi SAFC II w/ extension harness. $180
*SOLD* HKS turbo timer. $75
*SOLD* HKS VPC and GCC with wiring harness for a 1g dsm. 550cc injector chip I believe. (this has more than 2k miles, total unknown but it worked when pulled; comes with map and IAT sensors. $200
*SOLD* 3” mandrel bent exhaust for 1g AWD; down pipe to muffler; Magnaflow stainless muffler, 3” in 4” out. Includes test pipe for either a Galant VR4 or a Talon/Eclipse; whichever application needed. $250
5-spd. 1g Transfer Case. $100
*SOLD* 1g AWD 5-spd. Transmission. Equivelent of a Shep stage 3 w/ a 4 spider diff. Built by Beyond Redline in Green Bay, WI. Shifts perfect. $1000
Turbo setup. Precision GT35 journal bearing, mitsu flange; 2g ported exhaust manifold; HKS 38mm wastegate w/ dump tube, 2g o2 housing. $1000
*SOLD* JMF “race” intake manifold for 1g; `1g non turbo throttle body. $300
Fully built 6 bolt engine: Ross pistons .030 over, Crower rods, HKS 272 cams, Fidanza adjustable cam gears, 1mm oversized SI valves, 3g lifters, Crower springs, AMS machined balance shaft delete kit, New oil pump and water pump. ARP head studs, and main bolts. Mitsubishi MLS head gasket. Everything was blueprinted and balanced, powder coated valve cover. $2500
*SOLD* ACT chrome-moly 6 bolt AWD flywheel. $150
*SOLD* ACT 2900 clutch. $200
91 Galant VR4 Shell:
No engine, Ecu, Trans
Does have: 4 bolt rear end, Manual steering rack, Walbro 255 fuel pump, 5 lug hubs, 2g front big brake calipers, kyb gr2 struts. ABS was removed. $1800
*SOLD* Greddy Catch can. $40
*SOLD* Coil on plug w/ Intrepid coils. Wired for a 90’ dsm but can easily be rewired for a 91+ (I will rewire if needed). $125
*SOLD* Denso 700cc Injectors. $125
Pics
Catch Can and Coil on Plug
Galant Vr4 shell
Clutch and Flywheel
Timing side of engine
Trans side of engine showing turbo setup and intake manifold
Front of engine showing turbo setup
Bellhousing view of awd trans
Front of trans
Transfer case
Exhaust
Magnaflow stamp on Muffler
Hks VPC
HKS turbo timer
Apexi SAFC II
thedsmguy
Vancouver Washington
Can I say sold? I just sent the money.
I'd like to add that Cody so far has been a great seller, he called me on my phone to confirm the address etc. and shoot the sh*t.
Thanks!
cody
Neenah, WI
PM me if your serious about buying parts and Ill get you my paypal info. Thanks.
cody
Neenah, WI
Parts list updated with sold items. Ill get more pics of the C.O.P. setup as soon as I can.
Kitti
Active member
Bangkok
My engine is 2G.
it easy to plug and race? /ubbthreads/images/graemlins/grin.gif
thedsmguy
Since we are at the top of the list I'd like to thank Cody for the good transaction on the intake manifold.
Good luck with the rest of the partout.
