FS: Manley Turbotuff 6bolt rods
NateCrisman
Blairstown, NJ
Used for literally startup & 3 miles of driving before the vehicle was parted out.
Part Numer: 14413-4
Application: Mitsubishi Eclipse GS, GST, GSX & Eagle Talon TSi 2.0 (6 Bolt 4G63, 4G63T 1990-1993.5)
Center to Center: 5.905
Big End Bore: 1.890
Big End Width: 1.115
Pin Diameter: .827" (21mm)
Pin Bore: .828"
Gram Weight: 690
Forged from 4340 aircraft quality vacuum degassed material
Shot peened after machining to MIL spec and 100% individually magnafluxed
Specifically designed to handle high horsepower applications when using turbos and / or nitrous
Cap fasteners are 3/8" ARP 2000 cap screws
Flywheel horsepower range for these rods in a 4 cylinder application is 1,000+
http://performancepartout.com/manley-turbo-tuf-rods-6bolt-4g63/
