BluFalcon
Cleaning out some stuff around the garage, and found some items I don’t really want or need , so it’s for sale. Prefer a local buyer, but I will ship at buyer’s expense, unless otherwise noted. You've seen my Goodguy thread, and all that gushing praise still applies. If you want to use Paypal, that's fine, but tack on another 2.9% if you don't want to send payment as a gift.
1. 90-91 Eagle Talon Center Grill- I Have One Of These In Black. Good Condition, With No Cracks Or Broken Tabs On The Body Of The Grill. The Talon Badge In The Center, Does Show Signs Of Pitting And Wear, But Still In Serviceable Condition. -$35 Shipped
2. Magnus Billet 4G63 Reusable Oil Filter- I Bought This A Few Months Ago, And Decided I Really Didn’t Need It. Reusable Oil Filter With A Cleanable SS Filter Element. Element Can be Removed For Inspection And Cleaning. Never Used, Just Been Rolling Around In A Box For A While. Includes Fixture To Properly Disassemble And Reassemble Filter. -$100 Shipped
3. JMFab SS Exhaust Manifold Heatshield- Cutout For SB Racing Manifold With External Gate. Stainless Steel, Polished. -$40
4. 4 Bolt Axles- Spare Set Of 4 Bolt Rear Axles. I Believe These Are For A 1G Rear End, But Can’t Be 100% Sure As I Found These Loose In A Shop That Was Closing Up. I Have A Single Axle As Well, Which Can Go With the Set. Prefer Local Sale Only- $50 Set
5. HKS Throttle Body Elbow- Cast Aluminum, With Approximately 58mm Inlet/Outlet. Good Condition. - $60 Shipped
6. 2G Prothane Inserts- PN:13-502 Front Roller And PN:13-504 Rear Roller Inserts. Red, Brand New In Packaging. $20 Shipped.
7. HKS SSQV BOV- Got This In A Box Of Parts, After It Had been Disassembled. As Far As I Know, It’s A Genuine HKS Unit. Needs Hardware To Bolt The Cover To The Plunger Seat And BOV Body, Also Needs A New Nipple For The BOV Body. Includes Aluminum Weld On BOV Flange And Recirculation Fitting. Pick Up A Knock Off BOV For Parts, And You Can Put This One Back Together. -$20 Shipped
8. 76mm Accufab Throttle Body- Mustang Accufab Throttle Body Modified For Use On a DSM. Includes DSM Throttle Linkage On Shaft. I was Told This Throttle Body Leaks From The TPS Sensor, So That’s Why It’s Cheap. -$60 Shipped
