FS: maf chip and injectors
gaylantvr4
Omaha ,NE
i am selling my chip setup from my car. 482 maf with plug keydiver chip for 650cc injectors and precision 650 injectors. injectors will be sonic cleaned and flow before shipping. 300shipped
crazydriver81
Active member
Berlin, Germany
Quoting gaylantvr4:
Joe, which turbo charger you were running with this setup and what mods else have been programmed to the chip? I guess there might be more than just a correction of the A/F tables to accomodate the larger injectors...
coyotes
Seattle, WA
are the injectors plug and play with the stock harness? How would the chip do for the car without the cams? how much boost were you running?
Sorry for all the questions.
gaylantvr4
Omaha ,NE
the ecu reads airflow so cams add airflow witch is comped by the ecu. this setup will work with or without cams ect. injectors are plug n play. this whole setup will plug in with a simple rewire of the maf plug. the maf has the pigtail on it.
