FS: Longblock: 1g 6 bolt/2g head
SmoothCustomer
Lexington, KY
I have a 6 bolt block with 2g head, long block assembled. Unfortunately both the block and head are mysteries, so I can't guarantee they are okay, but they looked okay visibly. Comes with 1g intake/2g exhaust cams, balance shaft delete with proper spacer, intake manifold with egr blockoff, 2g coil pack, new ARP head studs, new OEM Aisin water pump, new composite head gasket, new timing belt and components, new fuel rail bolts/spacers, 90 oil filter housing, and that's pretty much it. You will need timing cover/crank pulley/exhaust manifold/thermostat housing/water pipe/alternator etc. I'll try to get pictures as soon as possible. $500 obo. Must be picked up in WNY, can probably meet somewhere within reason.
