BNIB 2G AWD 3" SS Megan Downpipe (will fit, and eliminates cat on GVR4)- SOLD
BNIB Fuelab Prodigy In-line fuel pump (140GPH 1300Hp)( link ) - $375
BNIB Isuzu slave cylinder- $40
New OEM Steering rack cushion (MB315228)- $7
New (2)OEM Front crossmember bushings (MB518168)- $20
Used OEM Knock sensor (worked when I took it out)- $10
Used OEM spark plug cover (decent shape)- $15
New (2) Vibrant 3" aluminum 90 degree elbows- $40
Used 1G Fuel rail-$10
Used 1G Fuel rail w/ -6an end- $15
New ETS 2"-2.25" reducer- $10
Used 2"-2.75 reducer- $10
New ETS 2" 45 elbow- $20
Powdercoated alt. bracket- $10
Used (approx. 500mi.)Taylor spark plug wires- $20
New Jegs -8an straight push-lock fittings (4)- $15
New Jegs -6an straight push-lock fittings (3)- $5
New Earls fittings
-8an to 1/2in. (700109)- $3
-8an to #10 o-ring (2)(AT985081)- $10
-6an port plug (AT581406)-$3
-8an bulkhead fitting and nut (AT983208,AT992408)- $7.50
-6an to 14mm x 1.5 (991954)(good for 4ws rack block-off)- $5
-6an to 3/8 tube (165006)- $7
-8an (m) to -6an (f) - $7.50
-6an (m)to 14mm x 1.5 (f)- $5
New Jegs push-lock -8an hose (10ft)- $20
