biglady112
I am going to try and get as close to 1100hp as I can on my new setup and this turbo is just not going to get me there. This thing has been very faithful and delivered a tremendous amount of power consistently for a very long time. It has absolutely no shaft play in either direction. The turbine housing has had the v-band flange turned down so you can center the ring correctly for a 4" exhaust/downpipe. The inlet flange has been modified to bolt up to a regular T4 footprint without issue. I have fed this thing with a -4 bolt on fitting with a .065" restrictor from the oil filter housing and have never had issues. I have used a -10 oil return without issue as well it currently has the 16cm exhaust housing. I will send the turbo with a stock compressor housing as the current one has a snorkel welded to it for a -10 sealed catch can setup and a 90* elbow I was using in a RWD configuration.
This thing made 800hp and 556tq@44psi through an automatic transmission. I will send it with cast hx52 71mm pro wheel that a friend bought and never used.
$475 shipped with PayPal fees
Pictures available if you ask.
Steven
720-483-9375
Steven
720-483-9375
