NateCrisman
Update 4/12: car is 100% parted and went to scrap. Today: update to sale lists and prices lowered
[email protected] for questions and paypal. Prices don't include shipping.
<b>PLEASE NO PM's....just email me. </b> I can't search PM's or keep track of info on 7 different forums, it's much easier for me to have all corespondance in one searchable inbox.
NGK plug wires $25
3” Turboback exhaust 150 (pretty rusty, Im going to see if sanding/painting can fix it up)
89 Tail lights $60
5lug swap set $100
Rebuilt 6bolt shortblock: 2g pistons, 90 rods, recent Tbelt, front case, and water pump parts <b>$500</b> Waterpump, front case, tbelt parts, oil pan, pickup, and hardware are cleaned and boxed up but come with.
1G head, ported, SS valves, farrea springs and retainers. <b>$500</b>
rear ss brake lines $20
DSG delrin shift knob $5
89 dash pad and glove box <b>$40</b> (These are dark blue in color)
Blue cloth galant GS seats (set of 4) $50 excellent condition!
13" front brake kit $175 (includes nice rotors, dual piston aluminum calipers, aluminum brackets, and SS lines. Brackets not shown in pics. The calipers are very light and from a camaro, rotors are from a mustang cobra.
Act 6bolt awd flywheel $100
HKS VPC and custom keydiver eprom chip <b>$200</b> - setup for VPC hardwired into the engine harness. Keydiver chip is setup specifically for the hardwired VPC to eliminate the "plug n play" ecu adapter harness. Includes MAP and AIT sensors with wiring harness. I believe there are 550 and 660 VPC eprom chips as well.
Alpine headunit CDA7839 <b>$40</b>
17x8” Acura TL wheels with tires $180
kirban afpr with -6 lines, 1g rail adapter, and gauge <b>$130</b>
Slim fans (2) $40 each one push/one pull
Pull
Push
<b>SOLD:</b>
93 headlight set 100
HKS 264/272 cams 285
Tien camber plates 120
Greddy profec B (blue) 150
FP exhaust manifold 160
Tial silver bov 145
Driven Innoventions SMIM for 1g head 375
Denso 720 injectors 120
90 OFH, -6 SS lines, 90 cooler set 65
battery relocation parts 75..nice SS box, cutoff switch, circuit breaker, and wire. Does not include battery.
Act 2600 clutch 150
3speed scattersheid 75
DSG AWD Galant fuel pump pickup 100
SS clutch line from frame rail to slave $20
Decent set of black (GVR4 specific) plastic timing covers $40
Indy Racecores 216 spearco FMIC kit 400
AEM wideband gauge 145
Dogbox racing rebuilt awd 1g trans. Have receipt. Evo forks, welded diff. 750
PTE SCM6152E T3T4 turbo w/ oil lines $425
ST rear swaybar 75
CF GVR4 hood w/ hoodpins 245
CF GVR4 grill 45
-6 fuel feed line from oem filter to rail w/ adapter $45
AFC blue screen (original version) 110
AGX shocks 200
3” intake pipe and filter 65
Autometer Sport-Comp 35psi, mechanical oil press, and electric water temp gauges $75
AEM fuel rail $75
non cruise throttle cable 20
ABS delete kit $65
Blitz turbo timer with 1G harness 50
Walbro 255 $55
Will be adding these parts to the DSMpartout.com website as I remove and get individual photos, so they will be available for online ordering. I'll also have another thread with all the oem stock parts from this car (non sunroof 91 white GVR4).
NGK plug wires $25
89 Tail lights $60
5lug swap set $100
Pull
Push
<b>SOLD:</b>
Tial silver bov 145
Act 2600 clutch 150
ST rear swaybar 75
CF GVR4 grill 45
AGX shocks 200
AEM fuel rail $75
ABS delete kit $65
Walbro 255 $55
