FS: Go Fast Pieces and some stock stuff
Boostin21
Wisconsin, USA
I need to move these parts so shoot me reasonable offers. They seriously need to go...
-Holset HX-52, this is a big boy turbo that flows well over 90lbs/min. Needs rebuild. $200 obo
-1g/2g AWD 4"-3" V-Band Downpipe, it starts at 4" off the turbo and flares down to 3" under the oil pan so that it'll be more compatible with a wider variety of exhausts. $300 obo
-Megan Racing 1g AWD 3" Catback. Mint Condition. $250 obo
-Vibrant Performance Universal Catch Can. Aluminum. Can be used in upright or horizontal formats. Sight tube included. Brand New In Box!! $90 obo
-(2) JM Fabrications Small Catch Cans, with -6AN fittings installed, come with pushlock lines. Evac those crankcase gases PROPERLY! $130 obo
-4" Stainless Intake. Relocates filter to factory side mount intercooler location for clean and cold air. Has fitting mounted for AN line to run with catch can setup. Makes a HUGE difference! $110 obo --- BUY WITH CATCH CAN SETUP AND WE CAN WORK OUT A DEAL!
-3" IN/OUT DynoMax Bullet Muffler, sraight thru. nuff said. $80 obo
-2g DSM Cylinder Head, low miles and very very clean. $200 obo
-EVO 8 Cams, these can be degreed properly to run on a DSM and since they are hollow they have less rotational mass, not to mention they have a larger duration than stock DSM cams. $100 obo
-2g Intake Manifold, clean. Comes with sensors. $35 obo
-2g Fuel Rail. $40 obo
-(2) 1g Intake Manifolds. Cleaned. $40 each
-1g Big Rods, low miles, in good shape. $50 obo
-NPR 2g Pistons with rings and pins. New In Box. $90 obo BUY WITH 1g RODS FOR A SOLID BOTTOM END!!
-TransDapt Dual Oil Filter Housing/Cooler Relocation. This houses 2 oil filters and is setup for -AN lines so you can remote mount your filters for extra clearance and still run a cooler if need be. Or use for added trans filters! $40 obo
-1g Datalogger setup, includes palm pilot and logging cable. Will need software loaded which can be done for free. $60 obo
-Turbo Gaskets, wide assortment, both hot and cold side gaskets. $30 obo
-92-94 7-Bolt Timing Belt Tensioner. Never used. $80 obo
-22 Spline Transfer Case with 88k on it. $50 obo
-Black Prothane Motor Mounts for 5 Speed 1g AWD, Just idle time/base tune time on these and all the sweat work is done so these are installed and ready to rock! $120 obo
-Sparco Universal Shift Knob. $50 obo
-Aeromotive a1000 Adjustable Fuel Pressure Regulator with Gauge. $140
-Aeromotive Fuel Filter -8AN. $50
-Suzuki Hayabusa Individual Throttle Bodies. Tell your Honda or AE86 buddies, these are awesome ITB's and have a new TPS already! $200 obo
Not really looking for anything unless its a Borg Warner Turbo (s300), Twin Scroll T4 mani, aluminum driveshaft (2g), upgraded axles (1g).
Cullen
