Lucas03ES
I have an entire garage full of DSM parts and I would really like to get rid of all of this stuff that I do not need anymore, and get my garage back!! If you need anything that you do not see listed here, just shoot me a text or call and I can see what I have. Everything is best offer, shoot me a number and we will work something out! Thanks!!
I only put prices on things because thats the site rules. EVERYTHING is negotiable
Lucas
702-371-4127
Parts wanted:
K&N 4x9" filter or equivalent
driver's rear dogleg
Aftermarket parts:
Steel braided short clutch line $10
1G front mount IC piping, 2.5", set for GM MAF, comes with all the t-bolt clamps and 3 couplers, and throttle body elbow. $65
ACT 2100 pressure plate and street disc 14k documented miles $60
Vision 10.2mm spark plug wires $15
Stock parts:
1990 interior wiring harness $50
1G rear motor mount awd $15
1G 347 front motor mount bracket $15
1G 347 front motor mount bracket cut for down fire turbo $15
1G transmission mount $15
1G transmission mount filled $15
1G speedometer cable $10
1G motor mount bracket driver's side (goes behind water pipe) painted red $10
1G single piston front calipers good condition with new duralast pads and fresh resurfaced rotors $75
3000gt vr4 fog lights w/ pigtails $25
1990 coil pack $30
(2) harmonic balancers $10
1G stock throttle body elbow $5
1G tranny/starter dust cover $15
1G metal dush shields that go on head behind cams $5
(2) 1G water pump pulley sets $5
(2) stock fuel rails with fpr $5
1G banana shift knob $5
(2) 1G head bolt sets (one set is missing two washers) $10
1G intake manifold w/ egr $35
1G driver side motor mount good rubber $15
1G brake master cylinder w/ reservoir $20
1G window wiper motor $20
1G radio bezel stock $10
1G radio bezel with 3 holes for gauges $15
1G radiator w/ aftermarket fan, excellent condition near new, was in my GVR4 $75
1G intermediate shaft and driver's side axle $70
2G AWD starter OEM mitsubishi $45
1G AWD fuel sending unit $75
2G stock intake hose $10
1G front struts w/ springs $75
Both 1G front lower control arms $50
1GA tail lights and center section Talon $30
1G dash grey $50
Lucas
702-371-4127
Parts wanted:
Aftermarket parts:
Stock parts:
1990 coil pack $30
1G dash grey $50
