Kenny_Kline
Cleaning out the garage and have a couple bin full of parts. I am going to list everything I have, prices will be posted next to each item. Anything without a price is best offer. I have paypal. Prices do not include shipping. Questions you can either call/text 508-367-5023 pics available upon request or email [email protected]
-Heavily ported 2G Exhaust manifold gasket matched on both sides to a 7cm gasket along with both surfaces resurfaced perfectly straight. $75
-Unorthadox aluminum underdrive crank pulley $20
-Vented catch can - plastic $20
-Joe P manual boost controller (silver) $40
-1G front lower control arms new ball joints and ES bushings $50
-Aluminum shifter base bushings new never installed $20
-Front water crossover pipe (non turbo-no coolant fittings for turbo) $20
-1G 2.5" downpipe, deletes cat expanded to 3" at the end, no flange $50
-FP oil return line for 14b/16G turbo with all new gaskets/washers (aluminum flanges/blue line) $40
-4 NGK 2262 plugs brand new in box $10
-Oil feed line from OFH to turbo includes all fittings to make work $20
-Autometer (ultralite) electric oil pressure gauge w/ sending unit $30
-Autometer (ultralite) electric water temp gauge (#4337) w/ sending unit $30
-Autometer (ultralite) boost gauge $30
-Wastegate acuator setup from a 16G turbo
-radio gauge pod tripple gauges retains radio from extreme PSI
-6AN male to male union fitting
-Galant gvr4 single gauge pod for pillar
-1G MFI relay
-1G transistor pack
-14B/16G hotside clamp ring
-1G Thermostat assembly (upper and lower) with all sensors
-Like new OEM timing belt (used for start up of old motor)
-2G OEM knock sensor brand new never installed harness cut at plug
-knock off ebay boost controller (blue)
-Banjo fuel fitting to convert to -6AN line on top of fuel filter to rail
-2.5" 90* 3 ply coupler blue
-2.5" 45* 3 ply coupler blue
-2.5" straight 3 ply coupler blue
- 8 2.5" Tbolt clamps
-2 3" exhaust clamps butt style coupler
-fuel rail fitting converts to 6AN line male fitting
-3 OEM fuel injector seats (rubber oem brand new, seats inside the head)
-1G TPS
-1G front subframe bushings brand new from ES
-1G MFI relay
-1G transistor pack
-1G TPS
