dsm10o0
Garage clean up again. If you see or need anything, pm me or call/text 408 600 6286
Prices are all obo,
pics in this thread.
Crower Valve springs and retainers with seats.
3g lifters
evo rocker arms
$200 for this set up. Can separate it if wanted
GM maf and translator for 2g, have 2g maf pigtail to wire into a 1g/vr4. $120
NEW Clevite 77 tri metal race main bearing $40 shipped
2.5 intercooler pipe with 1g bov $50
XTD stage 4 clutch, 4k miles plenty of life left. $50
Act street light flywheel,4k miles $120
22 spline t case $80
GVR4 full 3 inch turbo back exhaust $150 Pick up only
1g ported bare head, resurfaced and had new valve seals installed 3k miles ago $100
3 good wiseco pistons 9.0:1 on 1g rods. 1 piston and rod is not good $100
evo3 7cm turbine housing, has 1 broken bolt $40
New NGK BR8eix $10
Full function RWD intake manifold flanged for 75mm throttle body $500
punishment racing 1g intercooler core. $75
dejon 3 inch intake pipe with KnN air filter $75
ebay t3 manifold with 38mm wastegate flange $50
2g maf with filter $25
6 bolt oil pan $20
1g dual piston calipers with rotors and new brake pads $140
