1995 Eagle Talon TSI AWD
FOR SALE $13,800obo
***LAST NEW PRICE BEFORE PARTOUT 12,700 (12k If I keep the wheels)
Engine 2.3l stroker forged internal 6bolt
-Eagle chromoly 100mm stroker crank
-Eagle rods
-Wiseco .020 stroker pistons
-Clevite bearing
-Torque plate honed
-Main line honed
-ARP headstuds
-Mitsubishi MLS headgasket
-New OEM Front case/oil pump gears/BS elimination
-New OEM oil filter housing
-New OEM waterpump
-New OEM timing belt
-New OEM timing pulleys and hydraulic tensioner
-All new OEM gaskets
-New knock sensor
Cylinder Head
-All New Valves, guides and valve seals
-NEW OEM 3g lifters
-Super Tech high tension single valve springs
-Titanium retainers
-FP3X intake and exhaust cams
Exhaust/Turbo/Wastegate
-EVO3 manifold ported (fastened down with all new OEM hardware & stainless gaskets)
-Forced performance 3052 ball bearing turbocharger
-Turbo & manifold ceramic coated black/compressor housing cerma-chrome
-FP stainless turbo oil feed line(.030" restrictor w/ 10micron filter)
-FP turbo oil drain line
-FP 2.5inch v-band o2 housing
-Tial 44mm v-band wastegate w/ custom 304 stainless dump tube
-Custom 4inch 304 brushed stainless steel exhaust (very straight route)
-4inch stainless steel magnaflow straight through muffler
Intercooler/Intake
-Custom 4inch 304 stainless intake pipe with K&N filter
-Kinetic front mount intercooler (core size 24" long, 12" high and 3.5" thick)
-Custom 2.5 inch 304 stainless intercooler piping
-Tial blow off valve w/ v-band clamp
-Magnus motorsports sheet metal intake mani. w/ nitrous bungs
-Phenolic intake manifold spacer
Fuel/Management
-Walboro 255 fuel pump
-New OEM mistubishi fuel filter
- AN lines from custom welded stock fuel rail
-Aeromotive Fuel pressure regulator
-FIC 1000cc injectors
-AEM standalone engine management (gm5bar map, GM intake air temp.)
-PLX m300 wideband oxygen sensor unit
-Custom dyno tune by CRUDEBEAR (fine tune using load cell tuning technique )
-Autometer electronic gauges (boost, fuel press, oil press, coolant temp)
Miscellaneous
-17x8 Authentic Volk/Rays TE-37’s in Titanium gunmetal (with rare center caps)
-Advan A046 235/45-17 Tires
-DC stut tower bars front/rear
-B&M short throw shifter
-ACT2600 clutch
-ACT light weight flywheel
-SS braided clutch line
-New clutch fork, pivot ball, and throwout bearing
-Polyurethane engine mounts
-Non-cruise control throttle cable/ cruise control removed
-Air conditioning removed
This car has been built with the finest of details. Over $23k invested. This Talon is easily and safely making 420hp to the wheels on 92oct pump gas. And it will still get 21mpg if driven conservatively. Most receipts and documentation available upon request
The interior and exterior was very well taken care of over the years. It has been freshly detailed with a new cut/buff/wax done recently by Accutint in Bellevue. You may be able to negotiate with me, to included with the car, a brand new set of 235/45R17 Bridgestone Potenza RE030 tires and possibly a brand new windshield installed.
[email protected]
Please no calls/texts after 8pm
Ted
206-412-1557
FOR SALE $13,800obo
-Eagle rods
-Clevite bearing
-Torque plate honed
-Main line honed
-ARP headstuds
-New OEM waterpump
-New knock sensor
Cylinder Head
-NEW OEM 3g lifters
-Titanium retainers
Intercooler/Intake
Fuel/Management
Miscellaneous
-ACT2600 clutch
[email protected]
Ted
206-412-1557
