FS: 5 lug swap setup
thedsmguy
Vancouver Washington
Front and rear. I can send knuckles or just the front hubs, either way I'd suggest doing front bearings. The rear axle stubs are a direct swap and very easy to do.
$125 shipped for hubs/stubs. I can also sell brakes and rotors if needed.
Thanks.
thedsmguy
Do you want new bearings (highly suggested) they are about $40 a side for bearings and another $25 or so in labor to put the bearings in. Other than that I'd charge about $50 to do the physical swap. So, total with new bearings would be about $300 installed. I'd give you some used rotors as well. If you didn't want new bearings (if I have a set that is still ok for now) your cost to install is only the $50 to do the actual swap plus parts and I obviously would not need to ship so its more like $160.
coyotes
Seattle, WA
I already have front hubs so I'd only need the rear. I am interested in this, let's put it on the list of sh*t to do to my car this summer and I'll pay you for helping me out. If you sell this stuff don't worry, I have access to another rear subframe if Evan still likes me. /ubbthreads/images/graemlins/grin.gif
slugsgomoo
Tacoma, WA
Allan, I would expect that a fwd dsm might work, but hard to say without looking at the way the two rear setups work.
89Mirageman
Stantonsburg, NC
You are correct, 1g FWD DSM rear hubs are identical except for the bolt pattern. So all you would need to do is buy hubs/rotors. Assuming your FWD came with rear discs in the first place. If not you will need to swap the entire rear axle beam out since the ears for the calipers are welded on.
