FS: 4 bolt rearend $250 shipped
Newb question.... I can replace the stock aws with this 4 bolt right? My stock aws is missing one part that is no longer made and I've been having problems finding the part for it. And most of the aws lines are rusted out. From what i read, to reduce the cost of having headaches with the lines, getting a 4bolt rear end would eliminate that right? Whats your input on that... ?? My knowledge is not great with my gvr but I really want to drive it and that last obsolete part of the aws is leaving me hanging.
SouthCaliVR4
North county San Diego
^^^ you can run a four bolt with or without four wheel steering. What part do you need I just pulled the 4WS from 825 & other than the pump (part in the diferential housing) all is as rust free as I have ever seen.
The four bolt is stronger than the o.e. three bolt & typically has a limited slip. Both are good reasons to run a four bolt.
Well, I need the steering feed tube line that looks like this:
But if you have most of the 4WS parts, I'm more than happy to check all that out as well. If you can take some pix of it so I can see what I need, that will be awesome.
