FS: 1g dsm body parts, performance, drivetrain
codeofdastreets
Palm Harbor FL
I have a 1991 tsi in dark spectrum blue ( rare color), this is a full body part out.. Pm or text for pics 9176805970 Andrew
Primer bumper semi cut for fmic-60
Rear bumper good condition-100
Full 1ga wing kit-100
Talon tail light with center piece good condition-80
Center side moldings both sides-50
Side skirts with bottem door moldings flat black-50
Fenders in blue pretty mint no rust small dent on drivers side-130set
Clean 1ga coners-40
Both flip up head lights assembly-75
1ga head light lenses with grillmounting point for grill is cracked off had grill zip tied-40
1g doors-50
1g hatch-50
1g n/t hood-40
Interior parts
Clean 1g dark gray leather seats with door cards-250
Center console with side rugs-45
91 cluster 121k-40
Assorted small trims- best offer
Performance parts
Advid billet mounts 4 piece 80a stiffness-220
Fuel system-7 gallon fuel cell, aero motive a1000 pump, aero motive inline -8 filter, ss feed -8 ss -6 return... Fuel cell has custom mount so it can mount to stock tank location so floor board has to be cut out if u use my brackets..-500
Jmf bumper support-100
Thermal 3 in awd exhaust with buscher dp 1g- 300
Driveline
5 speed transmission 23 spline, welded center diff and steel shift forks, I know trams has been apart and rebuilt at one time but I have no info other then the stuFf I mentioned, trans has shifted into every gear at 8800 and has made 550 on the mustang dyno.. Trans shifts into every gear fine but has a slight grind in 3rd but goes in fine, my guess syncro..-250
23 spline t case-80
Both front axles mint with half shaft -100
Good starter with receipt-40
Oem clutch master (1000 miles), ss line master to slave, and good Oem slave, want to sell all together-125
Non abs proportion valve-45
Aftermarket Brake master with booster ( 100 miles on both)- 100
Welded petal assembly with shep bushings- 120
91 Good shifter cables-60
91 shifter box all bushings replaced-60
E brake assembly- 30
matt92vr4
Venice, FL
Newb question: Does the 92 Galant vr4 use the same 23 spline xcase and front half shafts as the 1G?
matt92vr4
Venice, FL
Cool Thx! Can you post a pic of the input spool of the case? How far are you from 34293 Venice?
