FS- #1425 - $10,000 - AL
TurboPickle
Member
Dothan,AL
#1425/2000
150,000 miles
Pros, recent maintenance:
Stock motor nothing crazy
Stock ECU
17” wheels
New shifter bushings
New tires.
New brake rotors
New valve cover gasket
Fresh oil
Fresh transmission fluid
Heat works
A/C WORKS great <——🤯
New compressor
New dryer
New blower motor
New Resistor (HVAC)
HVAC vents all function no missing fins.
Power mirrors work
Power antenna works
New reverse switch
No major rips in the leather seats
Newer paint. Couple years old
Newer clutch (2k miles)
Original fog lights.
No faded sunspots at all.
No sun rotted leather head rests in the rear. (Very common issue) as we all know
No rust
All trim pieces. Minimal damage
Original functioning head unit.
No sunroof
A88 trim
Mods:
K Sport Coilivers
16G turbo
Front mount
Momo steering wheel.
Boost gauge
Multi Gauge:
A/R ratio gauge
Voltmeter
MAF Translator
DNP exhaust manifold
Manual boost control
Japanese shift knob
LED bulb swap:
Reverse
Rear blinkers
Brake lights
Cruise control delete
New throttle cable
JDM Grill
5 lug swap
Cons:
2 gear will grind sometimes if you try and shift too fast.
Crack in the clear coat on one of the doors
Timing belt should be replaced soon
located in Dothan, AL
$10,000 is my lowest, no need to ask
