FS: 10 years worth of DSM electrical parts.
lunchbox
Mil-walk-it-out, WI
Selling my large collection of misc DSM electrical items. All were from cars I parted out that ran. 90% of the plugs have 4-6" of wire on them.
4x radiator fan harnesses (both sides)
4x rear 02 sensor (2G)
3x 91+ coil pack connectors
1x 97+ CAS connector
3x 91-94 coil pack and power transistor harnesses
2x 90 coil pack and power transistor harnesses
1x 91-94 power transistor
1x 2G MAs
1x home made 1G in a 2G harness for 97+
1x 91-94 CAS harness
3x 91-94 TPS tarness
2x 95-96 CAS harness
1x 2G crank position harness
1x 2G front oxygen sensor harness
1x 1G stereo connector (dash side, in case some idiot didnt use a plug-in harness)
3x 2G injector plugs (quick release)
3x 1G injector plugs (metal clips missing)
2x 1G knock sensors, one is nearly new
1x 1G idle switch
4x 1G marker lights with bulb socket
1x 1G fuse box cover
1x 1G rear wiper switch blockoff (factory)
1x 2G MDP sensor with harness
1x 2G sunroof crank
1x 95-96 CAS harness both sides
2x vacuum solenoids, one with harness
2x 2G front 02 sensors, one is new
1x 90 tach isolator
1x 90 coil pack and tach adapter (4 pin plug)
2x MPI relays
5x 1G 91-94 power transistors
3x 91-94 ISC motors
1x 91-94 TPS sensor
2x 90 power transistors
1x 2G power transistor
8x misc plugs I can't identify
Lets start it out at $200 but very open to offers.
