Front Subframe Bushings Question
atc250r
Orange County, NY
Can one of you that have done the Energy Suspension front subframe bushings answer this question for me? Does the bushings for the front crossmember come with the kit? I'm talking about the crossmember that the front motor mount (by the radiator) attaches to. The pics I've found only show three pairs of bushings and the front subframe has six bushings on it so I'm guessing that they don't give you the bushings for the very front. When I click on the instructions pdf on ES's site it doesn't work so I can't get the answer that way either.
John
christo
Fairhope, AL
I don't think so. But you can use the smaller set that comes with it on the front cross member.
atc250r
Orange County, NY
Thanks. I broke down and looked on DSMTuners which sent me to where I should have looked in the first place which was the VFAQ. The VFAQ article says the same thing as you did. The kit comes with all the parts to do the front subframe but not the crossmember. It also said that if you take the smaller bushings from the subframe kit they will fit in the front crossmember. I have the bushings here somewhere, tomorrow mornings mission is to find where the hell they are. Once I find them I'll order up another kit so I can do the front crossmember as well. When I pulled the crossmember out I found it had a pretty good kink in it. Yet another surprise the the previous owner failed to mention. /ubbthreads/images/graemlins/banghead.gif
John
