front axle carrier spacer
Does anyone know the thickness of the spacer for the front axle carrier where the AC bracket goes? AC was deleted when I got it, but it didn't have anything filling the gap. Would like to fix that.
vr4play
Cincinnati, Ohio
I can't remember exactly but I think I used 3 washers. When I measured there was only like 1 or 2 thousandths differance to the a/c bracket. I can measure a bracket for you tommorow if you would like. I have a few lying around.
Yes, but I can turn one for free in about 5 minutes /ubbthreads/images/graemlins/grin.gif
NARF
Vernon ,CT
Its been so long since I did mine I forgot the overall. Measure the thickness @ the through bolt when you remove the bracket.... that's how wide it needs to be /ubbthreads/images/graemlins/dunno.gif
Washers aren't a good idea. Its spacing between shims, not one solid spacer.
curtis
Clarksville TN
.2995 /ubbthreads/images/graemlins/grin.gif Its easy with the spacer hanging on a block on a stand. That will be one set of shifter bushings. /ubbthreads/images/graemlins/rofl.gif
