Found a gvr4 in the junk yard(not much left though)
3rdstrikedsm
32159, FL
It has been picked over pretty good and motor, trans,dash,seats,body moldings were all gone so not a whole lot left, I sometimes go there to see what they have and have been twice in the last week but I am not really planning any trips any time soon but if there is something I can help you guys with I will next time I go.
Note- a/c system is complete and still holding a charge but compressor is just sitting on front subframe with the lines attached so I have no way to tell if the clutch is good.
belize1334
Bozeman, MT
Can you look for the plastic grommets associated with the hood prop? There's one for the base of the metal prop and another that it clips into when stowed. I need both.
Struc
Oconomowoc, WI
Quoting 3rdstrikedsm:
I did snag the fuel pump sending unit today since it was in good shape.
Was the tank / Sending unit studs in good shape?
3rdstrikedsm
32159, FL
No infact I broke 3 of the studs taking it off, I did snag the a/c system and a few other odds and ends which I will be listing on e-bay this weekend.
