Actually, '90 DSM oil cooler housings face the same way as a stock vr4 housing and have provisions for an external air to oil cooler. I believe the forward facing filter housing is off NA 4g63's and doesn't have any provisions for cooling, although you could easily use an adapter from summit or the like.
Quoting icurunnin:
so has anyone run one? just want to know if I am going to be able to use it with my stock crappy cooler or if you have to go external when using one.
The stock water sandwich? That wouldn't work because non-water cooled housings don't have a detachable filter shaft.
so basically I would run without any oil cooler. gotcha. I dont think the stock does any good any how. I would like the room so its not such a pain to change with a larger down pipe.
