Fix for Crank Walk
centurion882
Mio, Michigan
Looking for someone to fix my 6 bolt motor????? Engine has been completely rebuilt with approximately a 1000 miles on motor !!!! Please call 989-370-5624 I live in Michigan but willing to travel to fix engine correctly!!! Thanks Dan
Leon_R
Chelmsford, MA
You need to rebuild the engine with a new crank. If you know why it might have walked, avoid doing the same mistake, if you do not know, get a new crank AND block, just to be sure...
thomcasey
Indianapolis, IN
If you have a heavy clutch, highly advise disabling the clutch switch. Pressure on the crank from having to push in the clutch on these is never good on the bearings. I wonder if there is a way to adapt the pull clutches to these, like on the EVO's, hmmmmm.
Dan, not clear from your post exactly what is needed, but I am south of you in Howell. I have assembled a few engines in my time.
curtis
Clarksville TN
Quoting thomcasey:
This ^^^^^ but Mr Iceman I'm sure has the problem under control. Hopefully you don't need a crank
