FEELER: 89 manual seat belts
luis84one
lynwood, ca
Here are pictures of everything. One piece is broken but i have the other piece. also the headliner trim suffered some damage to the mounting clips. I was thinking 200 shipped. Pls lmk if that sounds reasonable. Ive already contacted the first person to ask about it and ill go down the line until its sold. Sorry for not responding to the pms earlier Ive been busy getting parts together for 652..
quato
San Antonio, TX
Did you grab the seat belt buckle off of the seat itself? The manual seat belts will NOT fit the auto buckles. If needed I have a set of dark brown buckles for a manual belt set up. With the buckles sitting where they do, you can't even tell that they are brown.
Just wanted to make sure people know...
quato
San Antonio, TX
Also, you are missing the a-pillars. The manual belt a-pillars are slightly narrower where it joins with the headliner trim piece.
luis84one
lynwood, ca
I totally forgot about those pieces. I should have them tomorrow. Here are some pics if the broken piece. It was my mistake i set it down and accidently leaned on the corner /ubbthreads/images/graemlins/banghead.gif.. The headliner trims both have around three mounting clips broken but look flawless from the front and you can see the damge on the passenger b pillar
luis84one
lynwood, ca
Now its a complete set. I have the a pillars and the bucles. Only broke one mount on the druver side a pillar. I had to adjust the price because i didnt expect to spend more on this.
