Hi.. need help. Looking for an external wastegate diagram to where should i connect the top port and lower port of the wastegate. And also i'll be using a manual boost controller. Thank u i advance.
With a MBC you would be using ONLY the lower port. The top one will remain unused.
I haven't used a MBC or ran single port in a very very long time, so i'll let someone else comment on where is best to tap for the boost source in this case.
Lower port only and from a non vacuum source. Any where in between the throttle body and the turbo is fine. Most of the time I go right out of the turbo, there is usually a nipple. If not then I drill and tap and make a nipple.
