Hi all, i have been doing some search , but i couldn't find exactly what i want to know. here are my questions:
1)will the Evo8 suspension (shocks and springs) lower our car?
2)How harsh is the ride with Evo 8 suspension
3)How does the Evo8 suspension compared to other suspension choices? (handling + comfort)
Thanks in advance !!
1) No, it won't lower your car.
2) The ride is decent, e.g. it is better ride than AGX+whiteline or my old JIC-FLT-A2.
But if you have the cash, switch to hotbits. Hotbits both handles better and ride more comfortably than the evo suspension.
3) Here you go. I have tried most of the offerings for our car.
Higher number is better.
I do drive the car at track days, but not as often as I would like.
It is more of a spirited daily driver for me.
Code:
Code:
handling comfort Note
stock 1 4 soft stock car comfort, nothing to write about handling.
AGX+WL springs 2 1 A bit better handling than stock, but bounce bounce bounce.
JIC FLT-A2 5 2 Handles like it's on rail (8f/6r), not bouncey, but it's harsh/bumpy.
EVO shock+spring 3 3 Handles pretty good, more comfortable than JIC, probably due to softer spring rate.
Hotbits 5 5 Handles awesome (8f/5r). Shocks is valved perfectly, giving it a firm controlled ride.
IMO, handling at long sweeping corners ( on/off ramps ) is affected mostly by the spring rates. Higher spring rates give you less body lean.
How well the car absort bumps mid cornering is affected by how well the shocks is valved.
Ride comfort is affected mostly by the shocks.
( Hey guys, I'm trying to post the table of comparison above in fixed font mode so that the column alignment is preserved.. can someone tell me how to do that ? )
