EVO3 intake manifold.
Anyone have one of these? Are they better than ours? If so where can I get one? There are a lot guys on DSMtuners are running these.
It all depends on what you want to do with your car. If you want to hill climb or time attack(need lots of torque) with your car, I would say go with the Evo intake. For raw h.p. go with something thats going to flow more and has a larger plenlium. They are also smaller runners like the 2g, so if you decide to go with one you should have a 2g or an evo head.
That was fast an SUX, LOL I'm not going to swap the head anytime soon. Thanx man for the quick info.
for lots of torque also you can go with the cyclone witch i have and makes gobs of low end torque. The cyclone will be easier to find i think over a evo3 manifold. Good luck on your choice and let us know which one you decided to go with.
Yea but to run the Cyclone dont I need to hook up a vacume canister to operate the butterfly?
The vacuum canister is readily available from any Mitsubishi dealership, and you can use an old FPR solenoid to activate it.
