Evo 8 or 1g ignition timing?
bcjjones
leander, tx
Put an evo 8 ecu in my gvr4. I need to redo my ignition timing but im trying to figure out the best way. I cant go back to my 1g ecu anymore so im stuck trying with this one.
Basically should I just put it to 5 btdc? Also since the firing order is opposite id use the number four plug wire as the number one wire since the wires are swapped? If that makes since. And the curb idle plug is no use at all now because the evo 8 ecu doesnt recognize it?
Also, should I look up the 1g timing map and copy it over to the evo 8 ecu?
Any ideas on this guys?
tyeler18
Casa Grande, AZ
Definitely use the Evo 8 maps. The 1g/gvr4 maps are only "tuned" to 2 bar, the rest is all interpolated. Not at all uncommon to hit 20+ degrees of timing on 1g maps which is no bueno on stock pistons. The Evo maps if I remember right are tuned to 2.5-2.75 bar and then interpolated up to 3 bar, so your timing will be much safer below 21ish lbs of boost.
Also curious what you mean on the firing order needing swapped? I have an evo 8 ecu I've been trying to get to start on my gallant and didn't really read anywhere that it needed swapped around. I have done zero diagnosis as to why mine won't start, but this may solve my issue.
bcjjones
leander, tx
The firing order is swapped. Meaning number 1 on the stock 1g firing order is number 4 on the evo firing order. So basically the plug wires need to be swapped around.
I believe our stock firing order goes 4-3-2-1 looking at the motor
The Evo is 1-2-3-4 while looking at the motor, so they need to be swapped.
For anyone looking to do the base ignition timing, there is an option in evoscan for base timing in the actuator option at the bottom right. Click on it and its the same as grounding the curb idle plug under the hood. Then you just do the timing at 5 BTDC like normal.
tyeler18
Casa Grande, AZ
Firing order is still 4-1-2-3 so it doesn't make a difference. Worst case scenario they will fire opposite direction they would on a DSM, which won't effect anything at all.
Wizardawd
Franklin, NC
Evo still used the same wasted spark setup, just moved the coil packs to the valve cover valley. Cylinders 1 and 4 fired at the same time, as did 2 and 3. So as long as you have those pairs grouped, no issues.
Wiz
