evo 8 FRONT tein springs fit our gvr4 front strut?
oldman_tau
cerritos,california
i already did the rear and turn out fine. i wanted to know if the tein lowering springs off a evo8/9 would fit our gvr4 struts specifically FRONT? what do i need and any mods or bolt on? thanks in advance
broxma
San Antonio Tx
Will be exactly the same as installing the stock Evo springs. Fronts fit fine, Rears need either a cut coil or some sort of spacer to hold them in place due to winding diameter.
/brox
oldman_tau
cerritos,california
thanks. so you mean i can use an evo8/9 lowering springs with my galant kyb shocks bolt on?what top hat should i use galant or evo? thanks
broxma
San Antonio Tx
Galant.
I have Sprint Evo Springs on my galant in the front on KYB adjustables. I have modified K-sport camber plates but it fits perfectly with the stock mounts. The rears, you will have to modify like I said. You'll see what I mean when you pull it apart.
/brox
