nemovr4
Okay so I need some more suggestions..
I have failed emissions 5 times, and I am running out of options. So far I have replaced Spark Plugs, Wires, Air Filter, and oil. I have the EGR block off (correctly done) and have done several in depth boost leak tests, only a small leak on the BOV.
The car currently has 2.5 exhaust all the way through, with a hi-flow cat, which I am replacing as soon as I can find one. (suggestions welcome)
I put back in my 450cc injectors and made propper adjustments in ECMlink.
So far I have dialed down the fuel pressure to 37psi and failed both CO and HC...today I went in (fifth time) and ran about 2 gallons of E85 and 5 gallons of 91...lowered the HC but failed the CO.
Also it should be noted that I am only doing the idle and 2500 rpm tests because they are affraid of the 4ws sticker on the back /ubbthreads/images/graemlins/wink.gif
Anyone have ANY other comments or suggestions I could do to pass...the "boss" says if i dont get this figured out it will be going on Craigslist...
Help.
Thanks,
-Chris
Help.
Thanks,
-Chris
