ECU case
Imback
Suffolk,NY
I'm in need of a ecu case. I'm putting a locals car back together and would like to put the ecu back in the stock location. Thanks
Turbo99
Haverhill, MA
For some reason people want a lot of money for 6th gen galant ECUs. You can get a 94-95 galant ECU which is the same case for much cheaper (around $30 on ebay). Just make sure you look at photos of the back of it to make sure the riveted spots where the ecu mounts to the case are the same spacing. I got another random one without looking close enough at the back and some of the boards have a different footprint and use different holes for those riveted threaded pieces.
