DSM Link
strokin4dr
Savannah, GA
There is not a self learning feature on dsmlink. You have to modify the VE table yourself or use a program like Linktools (no longer available).
Megasquirt and some others has this feature but I've never used it on a Mitsu.
EHmotorsports
Beaverton
There is a semi self learn feature when running SD. after you take a log you can click on the Map and it will give you recommended values for the effected cells. but use this feature lightly as some cells will be wildly off and cannot be used.
strokin4dr
Savannah, GA
I actually forgot about that feature. Used it a couple times in the beginning. It will get you close in some areas but will leave lots of work to be done.
