Dont know how the vacum hoses go
galantrevolution
las vegas, nv
I just install my FMIC but im lost how to get the vacum hoses on, it look right but when im driving it wont boost, and if i move the hoses it will boost but it will cut off at 5psi, need some help here please.
The manual boost controller goes in between the wastegate acuater nipple and the nipple on the j-pipe
Diego
Quoting galantrevolution:
I just install my FMIC. I'm lost on how to get the vacuum hoses on. It looks right but when I'm driving it won't boost, and if I move the hoses it will boost but it will cut off at 5psi, need some help here please.
FIXED
Now, do you have a MBC or are you just running the stock BC on stock setting on a stock setup? What are your specs on the car? If you provide more info we can fix your problems. Take a picture and post it up so we can see where you routed your vac lines.
Diego
