Does the fog/signal lights plug and play wit the jdm bumper?
raptorWagon
Oak Harbor, WA
No, the foglight switch won't be plug n play, because on the JDM foglights there are two lights in one housing instead of just one like on the stock USDM lights. The lights will have to be manually wired up. Turn signal lights will also have to be moved to the corners, if you get a JDM bumper.
Proper grammar and spelling will see better responses to your questions /ubbthreads/images/graemlins/banghead.gif.
fuel
Toronto, ON, Canada
Quoting raptorreed:
Not quite.
There are two styles of fog lamps and bumpers you get on the JDM Galants - prefacelift and facelift. Now the actual bumper skin itself is the same, but the metal frame support behind it is different between pre-facelift and facelift as the fog lamps are a different shape behind the surface.
The pre-facelift fog lamps simply have one pair of fog lamps on the inside and a pair of indicators on the outside, like so:
The corner lamps are similar to your USDM lamps in the way they have two sets of small bulbs, one for parker lights and one for indicator repeater lights.
The facelift fog lamps are the ones which have two sets of fog lamps like so:
The outer projector style lamps come on when you flick the fog lamp switch, but if you have the headlamps switched on and on high beams the outer pair of fog lamps will switch off and the inner pair of fog lamps will switch on, they basically act as a second set of high beam lights.
Facelift cars then have the parker lights relocated to the headlamp housings and the indicator lamp takes up the whole corner lamp and there is now no repeater lamp.
fuel
Toronto, ON, Canada
some people wire up one set of the spotlamps to use as indicators when fitting the facelift lamps/bumper to pre-facelift cars. But you would have to use an orange coloured lower wattage bulb, you don't want 55W of bright white light coming from the indicators haha.
Yea your right i figure i use the outer lights as fogs and the inner as the indicator i went thru hell to find the bumper and the fogs thanx again
Also i wanted to noe the bulb size if its still h3 for fogs jus like the usdm bumper
alansupra94
Wayne,NJ
Nah I got USDM. I want to get a JDM bumper and JDM fogs. They look real nice.
I am more focused on getting the car running now then looks. Later on I will be tackling this /ubbthreads/images/graemlins/grin.gif
raptorWagon
Oak Harbor, WA
Quoting awdrick89:
Well that depends on if you're talking the facelift fogs or the pre-facelift fogs, I'm not sure if the signal lights in the pre-facelifted lights are H3s, I know the ones in my facelift fogs are though.
fuel
Toronto, ON, Canada
Yep H3s for both fog lamps themselves on pre-facelift and facelift, but the indicator portion on the pre-facelift uses the same single filament 21W bulbs as the corner indicator lamps on the facelift indicators or the same as the indicator and reverse lamps on the tail lights.
raptorWagon
Oak Harbor, WA
That's what I meant, I figured the foglight in those were the same, but wasn't sure about the outer indicator lights on the pre-facelift ones.
