cheekychimp
... or does the rate remain constant?
And what if the spring is progressive rate rather than linear? What happens if you cut coils from the bottom of the spring and or from the top?
Little bit of background to this. Did an MR Bilstein suspension conversion on the FWD GTi in the UK. Rear ride height was obviously higher than with the AWD because the rear shocks on the FWD mount on top of the solid axle cross member. I have tried to reduce this by using lowering springs to attain the 30 mm desired drop at the rear. The springs still aren't compressing to anything like that drop (I really can't see or measure any drop at all!) and I think this is because the spring rate is still far too high for the lighter car (no rear diff, no rear driveshaft section, plus further overall reduction in weight with no transfer case front driveshaft etc).
I understand the issues with dropping a car too low or cutting lowering springs to get more than 40 mm of drop and reduced shock absorber lifespan. Remember this is not the case here. I haven't achieved any drop at this stage as the spring rate is still too high for the weight of the car. There are other options to reduce the ride height by modifying the top mount location, axle mount location and the spring perch.
The issue however is that I currently am getting zero to minimal rear shock travel and zero damping affect from the strut piston. I need to reduce the spring rate AND drop the car so that I engage some piston travel and get some damping effect. The spring is an Eibach pro kit spring (already arguably the softest spring that I can find) and it is progressive.
Best/Worst case scenarios if I remove 3-4 of the dead coils at the bottom of the spring?
I know I can revalve the struts but I don't want to do that and even if I do it is pointless unless the spring is allowing the damper to engage.
Paul.
Paul.
