Difference in part numbers for jdm vs usdm vr4
dkvr4
CT
So it's been 6 days since owning my galant and it's time to order some parts for basic maintenance. Going to be going mostly OEM components unless if there's a better upgraded part (ie; cranky pulley - fluidampr). The sticky in the "how to" section has been really helpful as well as a thread on dsmtuners (http://www.dsmtuners.com/threads/dsm-maintenance-guide.476550/)
Just curious to see if there's a difference between usdm part numbers to a jdm vr4, I'm sure it'll mostly all be the same since it's a 6 bolt but with a cyclone intake manifold. When I was searching for a ngk wires part number I stumbled across a thread where the OP was asking what wires to use since he was using a cyclone manifold /ubbthreads/images/graemlins/dunno.gif Kind of threw me off since I figured it was all the same. So better safe than sorry I feel like asking before I go ahead and order all these parts.
Thank you in advanced!
"Most" mechanical parts will be the same, but there are differences. Plug wires for a Cyclone are different length because of where the coil mounts. I believe some parts of the ac sytstem (compressor and bracket?) are different also because of the Cyclone shape and location.
dkvr4
CT
Nice....so where would I find a part number for either stock or after market (ngk) wires to fit my car?
pot
Fayetteville, NC
Quoting dkvr4:
The NGK spark plug wires are part no. ME64. I think I paid about $42.00 off of Ebay but most dsm vendors will carry them.
They should fit, IIRC the NGK wires are longer than stock anyway (for more vehicle/model coverage), so I think they do reach.
Forgot about that thread, I have my coil pack mounted on the left strut tower. Leave it to curtis to engineer something for that.
dkvr4
CT
So just got off the phone with Magnecor and got a part number for wires specific for 4g63 with cyclone intake...very much on the expensive side (they quoted me $146.30+$10 shipping but found it online for $82.46 shipped) so I just may run these since it even list it for an 89-94 jdm Mitsubishi Lancer/colt/mirage/galant with 4g63 Dohc; with cyclone intake manifold. Shouldn't be too much of a difference between an 88/89 vr4 mechanics wise (only difference I found was the HP increase and different ecu part number in the 89)
FlyingEagle
THE Ottawa
Buy standard NGK 4g6X wires for any USDM/CDN model car.
I used the stock wires and it was pretty painless.
You will notice I swapped in the Cyclone dual runner intake manifold.
I did a write up of the process because I can't wrap my head around these things sometimes and need a reference to go back to.
Click for this thread: Galant VR-4 Forums » Galant VR-4 » Newbies » Cyclone Manifold Coils Transistors Installation How To - Bias to '89 Mirage/Colt
It's got lots of clear pictures to show how it all works. <img src="/ubbthreads/images/graemlins/rofl.gif" alt="" />
Or spend a few dollars more and avoid all that work.
