tyeler18
This is the Build Thread for Daily racecar, 736/2000. Reply below.
Never been on a dyno so now clue what power it makes. I'm on pump gas and 22lbs of boost right now so it's nothing crazy. Intake is just a 3.25" pipe into an evo MAF, the evo maf has made 500+ without issue, is there power to be gained without it? Sure, but not enough to make it life or death to swap. Gains are minimal.Hey, I'm going to spam you with questions. Have you been on a dyno? How much whp are you making? With 2150's i'd imagine its relatively high. What cams do you have? What's your intake setup? I see ur running maf but I was kinda under the impression you needed to go SD to not restrict yourself, so what maf is that? I'm making less power than I expected so I wanna see what your setup is. I think I need cams and a bigger SD intake to make it to the 350-400whp mark I wanna be at. Making 260 on a dynojet currently
Oh i thought you were on a red and that's why you were asking. 260 on a dynojet still sounds low for an HTA at 20lbs. We made 325 on 21lbs on a stock 6 bolt with intercooler and exhaust with a V1 HTA68. Car trapped 118? IIRC. Who tuned it?I'm running 20lbs of boost on pump 92. I have a 68hta and a bigger treadstone tr6 intercooler. FIC 1000's, and maperformance beehive springs with titanium retainers. DSMLink v3 with a 3g eclipse maf. Similar to ur evo one but worse
