Crossmember bolt information!
stealthtt24
Orlando, FL
So im installing my crossmembers back and im not sure where this piece goes exactly.
Here are my two crossmembers
And here is a pic I found but dont really know where that first little pieces goes.... thanks guys!
toybreaker
iconoclast
Passenger side of the rear crossmember.
It spans the gap and re-inforces the control arm mounting point.
stealthtt24
Orlando, FL
Ok thanks think I figured that out. But now I have a problem with the bolts I ordered.
Got 5 of mb176900 and those all fit.
Got 3 of mb240023 and 3 of them fit, but it looks like im missing one.
Got 6 of mb240024 and 2 of them will not line up with the driver side cross member even though they screw in. Then one on the passenger side crossmember seems like its too short to fit. Ill post up pictures...
stealthtt24
Orlando, FL
I found this picture
And I think im missing one 32166g (which is mb240023) and dont even have 32166h, since I dont have one long enough. Im pretty sure 32166f (mb240024) fits, I just need to line it up correctly. Coming with the pictures and maybe we can make this a How-To Crossmember bolts?
stealthtt24
Orlando, FL
Pictures!
First pic is the off center 2x mb240024 driver CM.
2nd pic is the rear of driver CM 2x mb240023 (I am missing one)
3rd pic is front driver CM with 2x mb176900
4th pic is front passenger CM with 3x mb176900
5th pic is middle passenger CM with 1x of 32166h, im missing this bolt therefor I do not have the part number.
6th pic is rear passenger CM with 1x of mb240024
Last pic is that weird metal thing shown in first post bolted up. You can see if you look closely there are 3x of mb240024 and 2x of mb240023
So thats 6x of mb240024, 4x of mb240023, 5x of mb176900, and 1x of 32166h part number unknown for now.
stealthtt24
Orlando, FL
Got the two missing bolts in and its all buttoned up! Pics of both crossmembers installed to come...
