Clutch pedal assembly
Brunoboy
San Bruno,CA Home of SFO
I'm assuming now my clutch pedal assembly is bad, two slaves and two master cylinders, adjusted all the way to the last thread and my pedal has about an inch up top of no Pressure before the clutch even engages or disengages. I can't get my clutch to full disengage with new everything and an extended rod. Anyone take out the clutch pedal assembly? Is it hard ? And anyone weld it to fix the "slop" of a warn assembly?
-shane
Eventually after about 190,000 miles the clutch pedal gets worn out, mine had got Soo bad that it wouldn't go in any gear anymore. Then i changed Them to new ones and bam works like new again. There's 2 pieces that u need to replace under there, the long clutch pedal and a small flange it connects too. All in all it's only about 25-35 bucks but they are a pain in the ass to change out because of the tight location. Some people do weld them though.
gramkrakr89
Bunker Hill, WV
i've heard that welding is an effective way to keep it from warping and such... my pedal is getting pretty bad too, but I got some more travel out of it by adjusting the top pedal stop up a little more...
the pedal sits a little higher now, but with the proper master adjustment, it makes a world of difference for opening up that little bit of stroke needed...
of course if the pedal assembly is getting worn, it is best to replace or repair it
Yeah man because once it gets to that point all the adjustment in the world won't help it if the metal in that flange is all boogered up. Just go to the dealer and order those 2 pieces, you'll thank me later
Brunoboy
ive been replacing masters and slaves like no other, I do have a XTD Stage 4 in it with the 6 puck unsprung disc for the past 12k miles. I adjusted the cruise switch out for more pedal play and adjusted the master rod out to the last thread with about an inch of the clutch pedal feeling no pressure. I assume my pedal assembly is done and the car itself has 221,xxx miles on the damn assembly.
-Shane
dsm10o0
San Jose CA
Ted could weld that up. I remember him having that problem. Its a bitch to get to, I had to take the dash off of my old Sgt when it had that same problem. /ubbthreads/images/graemlins/banghead.gif
Brunoboy
sgt? lol yea Nico, wanna come over and pull this out for me? ahahaha, jk, but i hope it doesnt take to long, i read many write ups on how to remove it. and I am pretty sure thats what it is.
It'll take atleast 4 hours with all the crap you gotta take out under the dash, not to mention you will be upside down all up in the dash 100 percent of the time so a smaller person would be more ideal for this job.
do u have the 2 new pieces or are you going to just have it welded? theres alot of stuff u need to remove under the dash in order to get the pedal assembly out. goodluck man
Brunoboy
i took off all the bolts, i took off the master cylinder, i took off the brake booster, i took off the steering column plus the steering shaft. i am going to take it out and see whats wrong with it. I cant even twist it around to get it out and if i pull forward its pulling the speed cable.... any help would be nice.
-Shane
cupajoe
Cocoa, FL
I remember doing this a couple years back, its just a pita. Aslong as the bolts are all removed and you pulled the brake boost away from the firewall there should be nothing physically holding it back. Use a flat head to pull it away from the stud(Floor)then just keeping playing with it until you can rotate it out from under there. Good luck, I'm going to have to be doing this soon with my galant.
EDIT: Did you read the write up on dsmtalk from Taboo? If you need a link I can link it.
Brunoboy
so i got it out, the speed sensor was in the way, pulled for slack and the pedal assembly came out. it seems fine, no play, im having it welded anyways since its out, I dont want to ever have to pull this again.
I'll Prob have mine welded in my other cars since its like a permanent solution. its the GST that i actually replaced the new stuff with.
cupajoe
Cocoa, FL
Quoting brunoboy:
Sorry I'm a little late on the link, just got home. But glad you got it out and I agree might aswell weld it while its out.
