Clutch Pedal Assembly Rebuilds
Sheptrans.com
Scroll down almost to the bottom.
If you're going to pull the pedal assembly yourself you may as well rebuild it yourself. Getting it out of the car is by far the hardest part.
464/2K
Denver,Co
As far as I know, you just replace the entire clutch pedal. A new on runs like $130 I *think* don't quote me. Also it's like a 3hr job rumor has it.
Depending on how much/if the pedal and arm are worn you either replace them or you can just install new bushings and have your original arm welded to the pedal. Took me about 3 hours the first time I pulled one, putting it back together was even quicker except for bleeding the clutch and brakes.
Be sure your clutch cylinders are not leaking and properly bled (if you haven't already) before you pull the pedal assembly. You don't want to go through all that work to find out it wasn't the problem.
dmj
orlando FL
Just rebuilt mine . the whole kit cost me just over 70.00 from JNZ prices may have gone up Took me 1.5 hrs to get the whole pedal assembly out from the car. Not that hard to do. If you need instructions (1) take off underdash panel above fuse box 2 threaded screws 3 self thread screws. (2) remove steering column covers 4 self thread screws (3) there is a bracket that holds relays that bolts to the dash and to the side of the fuse box 5 bolts and 3 nuts must be removed.(4) you can now drop the steering column by removing 8 bolts 4 upper and 4 lower. these bolts have larger washers than the ones on the pedal assembly so keep them together. (5)remove 5 upper bolts on pedal assembly then 5 nuts from where it bolts to the brake booster. remove cotter pins from cluth and brake pedals.(6) go under the hood and remove the 2 12mm bolts from the clutch master cyl. and disconnect the speedo cable this gives you room to wiggle the pedal assembly out of the car because you have to clear the clutch lever over the cable when removing. Feel free to pm me if you have any questions.The biggest hassle with reassembly is you have to compress the clutch lever spring before reassembly you need 4 bushings, the clutch pedal and clutch lever to do the rebuild.
