Clutch or tranny problems
ever time I drive the car and put it into gear it grinds a little and goes into gear with no problem mostly on 1.2.3 it does this most of the time.. and at times it s goes in smooth if I have the clutch pushed in all the way and shift it slowly ..any suggestions would really help thanks.
ggsxkid
La vergne TN/Lake Zurich IL
^^^ Im gonna side with diego, but their are so many factors that come into play. Like clutchm pedal height/adjustment, worn linkage, faulty/on the way hydrualic parts, Bent clutch forks, Worn Pivot balls Etc. I would drain out the old fluid put some Redline MT 90 gear oil (cap 2.3 Qts) in it and see if you cant adjust the pedal under the dash.
well i Adjusted the pedal under the dash feels a lot better but i still get that grind here and there not as much as before but still there when im shifting fast during city driving but im going to drain the oil and see if that helps out... I check out the Redline but seems a little pricey for me at the moment
are u loosing clutch fluid does the clutch feel spongie.Does it pop out of gear
No fluid leaks , and no it doesn't pop out of gear it just grinds a little but not that nasty grind its a smooth.grind but pops into gear with no problem
